22
This discussion topic is read only This discussion topic has been answered Discussion topic: Connect iPhone to SkyQ box
This message was authored by: Wizzer1966
Please can someone explain how I connect my iPhone to my SkyQ box as can't find any info on it on sky website? I have multi screen as also have a mini box. Thanks
This message was authored by: Roger+Peters Answer
Re: Connect iPhone to SkyQ box
Locked
@Wizzer1966
You connect it using Airplay
You can only use it to stream audio, to a Sky Q box, not video.
https://www.sky.com/help/diagnostics/listening-to-music-from-your-device/sending-music-from-my-devic...
Avatar for Wizzer1966
Level 2 icon
Many thanks for your your response. I'm not looking to play music just watch recorded programmes so how do I connect to my box to be able to do this? Thanks
@Wizzer1966
You can only stream audio from an iPhone to a Sky Q box using AirPlay.
To watch anything on the Sky Q box on your phone, you need to download and use the Sky Go app from the App Store. That will do what you want.
Level 2 icon
Thanks for that but unfortunately that's the problem I have the app but it's not reading my skyq box and website doesn't say how to do that?
This message was authored by: mike+simmonds
Hi @Wizzer1966
Advice from @Roger+Peters  spot on
Just one thing - are you using the Sky Go app as he says and not the old Sky Q app ?
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Level 2 icon
Thanks for your reply. Think I've sorted it. Realised that we only have the use of two devices and was trying to add my iPhone when already have my iPad and wife's iPhone connected. Regards
This message was authored by: Tyrer
If you have sky multi room you should be able to add 6 mobile/tablet/laptop devices.
Everything is beautiful.
This message was authored by: Nicola212
How do u connect phone to sky go app?
This message was authored by: Morgan+McDonnell
@Nicola212   By downloading and installing the Sky Go app?
Hi @Nicola212   By downloading Sky Go from the App Store.
I have already done that
@Nicola212   In which case you will need to elaborate on your question.  Do you have multiroom subscription?  If so you shouldn't have issues.
This message was authored by: bob1234
@Nicola212  Look in settings to make sure it is set to connect to Q Box.
Locked
