Discussion topic: Conectivity problem
This message was authored by: Val12345
Message posted on 12 May 2023 11:32 AM
Conectivity problem
TV shows conectivity problems using sky mini q
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 May 2023 12:34 PM
Re: Conectivity problem
@Val12345 Have you tried rebooting your main Q box ie
then
rebooting your mini box
as the mioni box gets it's signal from the main box
