Discussion topic: Clarification on fast-forwarding through adverts.
This message was authored by: James363
If I get Sky and I pause live TV for, say, 30 minutes, can I then:
a) instantly return to the LIVE tv broadcast (so miss the 30mins that was paused)?
b) fast-forward through that 30 minutes which would include fast-forwarding through adverts?
Thanks for any help.
Re: Clarification on fast-forwarding through adverts.
With Sky Q, yes and yes
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Hi @James363
Yes to all.
If you use live pause for any period (up to one hour) you can immediately return to live TV by pressing the dismiss button twice,  No need to fast forward which you can if you do desire.
To Skip in recordings playback best to use Q Voice control.
To skip adverts say Skip X minuets.  Adverts vary with each channel. For Exampkevtor ITV they are approx 4 minuets 15 seconds
@James363 wrote:
If I get Sky
Sky Q, yes.
Sky Glass/Stream, no (without extra cost)
