Discussion topic: Chicago PD UHD
This message was authored by: P77
Chicago PD UHD
Where's the ultra HD version for series 12 episode 5???
Re: Chicago PD UHD
With all the others @P77
Avatar for P77
Level 2 icon
Re: Chicago PD UHD
Yeah I tried it, it doesn't work...🤷
Re: Chicago PD UHD
Works for me.
Re: Chicago PD UHD
Is your Q box set to 2160p resolution @P77 ?
This message was authored by: Kt41
Re: Chicago PD UHD
So how did you get that to come up! As when I go to mine it just gives me watch from start or add series!
When I go into my settings on my sky glass and change it to uhd it still doesn't work!!
