Discussion topic: Check signal cable
This message was authored by: Mandeep7
Check signal cable
My sky q box is not working
Avatar for Mandeep7
Re: Check signal cable
It's just saying check signal cable
@Mandeep7 Have you tried rebooting your main Q box ie
then reboot any minis you may have
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: trafalgar
Same here, skyq working but will not connect through hdmi, just says no signal. I have tried every fix under the sun including reboot & new hdmi leads. Will have to contact sky tommorrow👍
