Discussion topic: Check Subscription mini box not working
This message was authored by: Howard251
We subscribe to 3 minu boxes and theryre not gettingall sjy channels
Avatar for Howard251
Re: Check Subscription mini box not working
Sky sports not working on mini boxes
This message was authored by: ThePope27
Hi @Howard251,
First off, only 2 mini boxes will work at the same time if you have the 2tb box or the 1tb hdr Main box.
Try this on your main Sky Q box go to Settings > Watch on Sky Q Mini Box > Reactivate.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
We have 4 mini boxes and sibscribe to 3 !
there's only two on and won't get sky channels or sports , this only just happened this week
Hi @Howard251
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
@Howard251
Just try the reactivation first before messing with the wifi networks.
EDIT: Are you getting the channels in question on your main box ?
