Discussion topic: Check Connection Message
This message was authored by: Meg0001_
Most times when initially switching on my Samsung TV I keep getting a 'Check Connection'  message, I have to switch the TV off and On a number of times before it connnects to Sky TV? Can anyone give me some advice?
This message was authored by: Me134
Re: Check Connection Message
That'll be the TV showing the message then? Try turning both off and removing the HDMI lead and either putting a different cable back or perhaps a different TV HDMI port. Make sure both ends are fully seated.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
