Discussion topic: Channel myhem
This message was authored by: Greeny17
Channel myhem
I click on a channel then have to put in my pin code then it plays channel for about 5 mins then says technical fault try again later. It's doing this on every channel anyone know why
Re: Channel myhem
Hi @Greeny17   Have you tried a power reboot of your box?
Avatar for Greeny17
Re: Channel myhem
Tried that pal thanks still the same and there's no heavy clouds in my area
Avatar for Greeny17
Re: Channel myhem
Now it's saying problem with broadband
Re: Channel myhem
@Greeny17  Sky Q, where you have posted, receives live channels via satellite & broadband would not affect it, do you actually have Sky Stream?
Avatar for Greeny17
Re: Channel myhem
Think it's sky q pal
Avatar for Greeny17
Re: Channel myhem
  • Sorry about this I'm old school ain't got a clue about technical stuff
Avatar for Greeny17
Re: Channel myhem
It's saying not connected to network I've punched in my password and tried pushing the button on side. It says connection to broadband router x connection to Internet x and keeps checking
