5
This discussion topic has been answered Discussion topic: Channel 706 schedule issues
This message was authored by: Tom+H+UK
I am unable to schedule recordings on channel 706 for next week (1st September 25)
This message was authored by: nigea99 Answer
Re: Channel 706 schedule issues
@Tom+H+UK wrote:
It just reads "this is colors" from 07:00 on Monday morning,  is there any issues?
hi @Tom+H+UK
The data is supplied by the channel itself & you probably need to contact them, although as it is part of the EPG you could try emailing Sky Viewer Relations : [email protected]  although they may just refer you to Colors
It might get corrected as we go through the weekend
Avatar for Tom+H+UK
hi @Tom+H+UK
Avatar for Tom+H+UK
Thanks nigea99  I've been trying  contact sky for assistance but they are unreachable   we will take your advice and see if it corrects itself over the weekend but it's been like this since Tuesday 26th August 25. Thank you.
This message was authored by: AJS-04
I did have the same problems, then, I chose another time for the recordings and it allowed to record series, for example if your program was at 7.30pm and recorded at 1.30am or 3.30am, or  untick all recorded programs and start from scratch, I hope this helps
You might be able to help ??
Colours channel 706 is standard not HD, are your programs being broadcast with subtitles, as there are not many people i guess watching colours Thanks in  advance
