Discussion topic: Changing channels
This message was authored by: Millie131
Changing channels
Whenever I try to change channel it takes 2 - 3 mins for the channel i have chosen to appear on my tv
Re: Changing channels
@Millie131
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
▪️I AM NOT A SKY EMPLOYEE ▪️
