Discussion topic: Changing channel
This message was authored by: Jakrow
Changing channel
We get to home page and choose channel-fine. Come to change channel and screen goes blank but sound of existing channel stays on. End up having to turn everything off and back on again. Help.
Re: Changing channel
Hi @Jakrow
This message was authored by: Japester36
Mine has just started doing this since 9:30pm.
Tried powering off. It went through it's normal cycle to the blue screen then rebooted itself and now it's started up.
It's incredibly slow and I have the same behaviour when changing channels as Jakrow.
2Tb box, Hardware version 32B106 with Software Version Q210.000.06.03L
Also now getting Technical Fault on Channels 101-105.
Satellite shows as locked okay, everything else in settings shows as okay.
Avatar for Jakrow
got as far as re pairing remote, then tv saying To use this service, you need a satallite signal????
Avatar for Jakrow
ooh! Seems to be working at the moment. Many thanks 😁
It was still in the same state this morning but is now working.
@oldfella Resetting the settings worked for me too. Thanks for the suggestion.
Avatar for Jakrow
@Japester36 today we just keep getting No Satellite Signal 😡😡😡
@Jakrow So far, ours still seems to be working. I'm at the office but my family are using it in anger today.
This message was authored by: Sunsetchris
My tv is stuck on on channel.Unable to change or go to any menu of home
This message was authored by: SlenderRobert
Tried replacing the batteries in the remote? Turn the box off at the wall for 30 seconds then power back on and see if that fixes it.
This message was authored by: Super+Anthony
Mine does this occasionally. I have told this to the complaints team along with other issues. I find the only way to deal with it is to reset the box. Very frustrating
(Please Note: I am Neurodivergent )
@Sunsetchris Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
