Discussion topic: Changed to Fibre
Message posted on 07 Apr 2024 07:40 PM
Changed to Fibre
Changed supply & now network keeps dropping out.
on mini box can't change to new WiFi?
Message posted on 07 Apr 2024 07:54 PM
Re: Changed to Fibre
hi @BandJoe
Unless you are on Sky Broadband mini connects to main Q box and not your Network.
First connect your main Q box to your new router.
Once you get your Main Q box connected try Network Reset on the mini.
