Discussion topic: Catch up
This message was authored by: Gandalf10
Catch up
When we log into catch up it says no programmes available
Re: Catch up
Hi @Gandalf10
Looks like you may have no internet connection on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max Router) then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
