Discussion topic: Catch-up tv
This message was authored by: RyanAub
Message posted on 17 May 2023 04:35 PM
Catch-up tv
Can't download catch up tv, says I need to upgrade. I've tried changing the download format and it still doesn't work
Find out more
Message posted on 17 May 2023 04:51 PM
Re: Catch-up tv
Hi @RyanAub
Did you change the format in preferences?
It's best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
