Discussion topic: Capping dish mount holes
Message posted on 28 Sep 2024 11:49 AM
So, we've moved from a dish to Stream and removed the dish from the brick wall. Left with 4 holes and whilst I can simply fill them with silicone or epoxy I want to use the plastic caps , the knock in type that engineers use when installing and make good holes from ladder stays . Anyone know what their correct name is and a source?
Message posted on 28 Sep 2024 12:37 PM
Re: Capping dish mount holes
@Scimitargtv wrote:So, we've moved from a dish to Stream and removed the dish from the brick wall. Left with 4 holes and whilst I can simply fill them with silicone or epoxy I want to use the plastic caps , the knock in type that engineers use when installing and make good holes from ladder stays . Anyone know what their correct name is and a source?
Something like This
Sky Q 1TB UHD
LG TV
Sky Mobile
