Discussion topic: Cant sort favourites
Message posted on 09 Jan 2024 06:16 PM
Message posted on 09 Jan 2024 06:22 PM - last edited: 09 Jan 2024 06:22 PM
Re: Cant sort favourites
First thing to usually try is rebooting the main Sky Q box.
~ press the 🏠 button
Message posted on 09 Jan 2024 06:44 PM
Super thank you. Thats worked 😊
