Discussion topic: Cannot play sky
Message posted on 20 Sep 2023 02:11 PM
Cannot play sky
Can't get my second sky box to work. It's says to press and hold the arrows till it flashes and it's already flashing
Message posted on 20 Sep 2023 02:26 PM - last edited: 20 Sep 2023 02:27 PM
Re: Cannot play sky
@Rosebudbaldo2 when it says press and hold the arrows it means on the nearest piece of Q equipment either main Q box or if you have Sky broadband you can do the same on the router if you don't have Sky broadband you can only press the WPS button (the one with arrows) on the main Q Box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
