Discussion topic: Cannot pause or rewind bbc oct 2026
Message posted on 11 Oct 2026 06:54 PM
From today cant pause or rewind bbc channels on sky q
Message posted on 11 Oct 2026 06:56 PM
Re: Cannot pause or rewind bbc oct 2026
@sdd123
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ Using the Sky Q remote put your main Sky Q box into standby
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 11 Oct 2026 07:01 PM - last edited: 11 Oct 2026 07:13 PM
Ive done this and a settings reset .
