Discussion topic: Cannot connect sky box to internet
Message posted on 12 Aug 2023 08:27 PM
My sky box is not connecting to the internet
Message posted on 12 Aug 2023 08:40 PM - last edited: 12 Aug 2023 08:40 PM
Re: Cannot connect sky box to internet
Hi @Feeeee
Assume this is your main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
