Discussion topic: Cancelling
This message was authored by: Ompa
Cancelling
Need to cancel sky in the cooling of period
Re: Cancelling
Best to contact Sky for that.
Re: Cancelling
@Ompa
If you successfully cancel you should receive an acknowledgment email from Sky.
After cancelling return packaging will be sent out for any loaned equipment Sky are expecting back. It’s important that you obtain proof of posting and keep it safe and indefinitely.
Avatar for Ompa
Cancelling
I want to cancel my order I did two days ago
Re: Cancelling
@Ompa
Your second post (moved here) is confusing. Have you only ordered Sky Q, or as this mornings post suggested it has been fitted and you are in the cooling off period?
Re: Cancelling
