Discussion topic: Cancellation
This message was authored by: Not+enough
Cancellation
Hi just wandering can you cancel part of your subscription it's getting too expensive
Re: Cancellation
@Not+enough
To remove a part of your TV package you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
To fully cancel your TV subscription, if your minimum term has ended you’ll need to give Sky the required 31 days notice. Note that the latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree. (If they agree you’ll have to pay the remainder of your discounted term).
See the below link
https://www.sky.com/help/your-account/my-account-and-subscription/cancelling/cancel-my-subscription/...
Select ‘No, I still need help’ at the bottom of the link which will lead to contact methods.
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ It may include a phone number, an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ there’s a text option (Monday-Friday 9am to 4:30pm) otherwise it’s only by calling Sky Ireland or writing in.
If you successfully cancel you should receive an acknowledgment email from Sky.
Remember that billing continues through the notice period after which a credit for any overpayment will show on your bills and should be refunded in about 6 weeks from your last day of connection.
If you are cancelling Sky Q, return packaging will be sent out near the end of your notice period for any loaned equipment Sky are expecting back. It’s important that you obtain proof of posting and keep it safe and indefinitely.
