Discussion topic: Cancel Netflix from my sky package
This message was authored by: Paul+simmi
I want to cancel Netflix and sky UHD from my sky package how do I do it
Re: Cancel Netflix from my sky package
@Paul+simmi
To remove UHD you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
For Netflix, contact Sky giving the usual 31 days notice if you pay Sky directly for it.
