2
This discussion topic has been answered Discussion topic: Can’t use my mini box
This message was authored by: Oludee123
I wrongly reset the mini box and now it seems my remote won't work with the box
This message was authored by: Laing1 Answer
Re: Can’t use my mini box
@Oludee123 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Oludee123
Level 0 icon
Thanks that works
