Discussion topic: Can’t rewind or pause live tv
This message was authored by: Divatt
Can't pause or rewind live tv
Re: Can’t rewind or pause live tv
Hi @Divatt
Have you tried rebooting your Q box?
Avatar for Divatt
Hi yes I've done that 3 times now , still can't pause live tv
Hi @Divatt
Just for info I removed your previous thread as no need to create multiple threads on the same issue.
@Divatt
You've posted the same issue on the Sky Q and Sky+ boards so please confirm which you have.
▪️I AM NOT A SKY EMPLOYEE ▪️
