This discussion topic has been answered Discussion topic: Can’t get sky sports + stream on my mini box. Any advice.
Message posted on 11 Aug 2024 03:25 PM
I can't get sky sports + on my mini sky q box. Any advice. I can get it through main sky q box.
Message posted on 11 Aug 2024 03:46 PM
Hi @steolikat
Assume you are on Ch412 on the mini and trying to use the red button?
Reboot the mini as above.
Hi @steolikat
Message posted on 11 Aug 2024 04:19 PM
Re: Can’t get sky sports + stream on my mini box. Any advice.
@oldfella @Thanks worked a treat. Cheers.
Message posted on 12 Aug 2024 01:53 PM
Is it possible to watch 2 sky sports red button games in different rooms with skyq main box and mini box? thankyou
Message posted on 12 Aug 2024 02:14 PM
@moh77 yes it is
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Aug 2024 02:46 PM
thankyou for your help and quick reply
