Discussion topic: Can't connect multiroom mini sky Q box to broadband
Message posted on 17 Dec 2024 05:18 PM
I've just changed broadband provider (not fibre) and now my Sky Q mini box won't connect. I've tried going through the set up and status suggestions, I've tried unplugging it and turning it back on. I've tried restarting my main Sky Q box and checking the multiroom is ticked but I still can't connect. I've even tried entering the IP address manually. Any suggestions?
Message posted on 17 Dec 2024 05:33 PM
Re: Can't connect multiroom mini sky Q box to broadband
Hi @SplashofRed
If you are now on 3rd party broadband then the minis if using WiFi will only connect to the main Q box and not your 3rd party router.
Message posted on 17 Dec 2024 07:31 PM
@oldfella, thanks for the reply. I've tried everything you suggested but my mini box still won't connect to my Sky Q box. Any other ideas?
Message posted on 17 Dec 2024 07:33 PM
Hi @SplashofRed
Did the WPS light flash when you carried out the Network reset onthe mini ?
And if so what happened when you pressed the WPS button on the main Q box?
