Discussion topic: Can’t connect any mini box
This message was authored by: Nic111110
Can't connect any of my mini boxes! Been trying for over an hour and am now missing the football I wanted to watch
Re: Can’t connect any mini box
Hi @Nic111110
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the mini. Start with the mini nearest to the main Q box.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.   You can also connect by WPS to a previously connected mini if it is the nearest Q device.
