Discussion topic: Can’t connect a Q mini
Message posted on 30 Jul 2026 06:39 AM
Hi All
as title, I have 4 minis (I know I can only use 2 at the same time) my problem is that one has been turned off at the plug for a little while in a spare bedroom, I have guest coming to stay and want to connect it back on the network, but as hard as I try it won't connect to the main Q box, I even hard wired it, but still nothing.
I've done all the usual, but still to no avail.
im thinking it may not be updated with the current version as its been turned off.
So any help would be appreciated
Many thanks
Message posted on 30 Jul 2026 06:44 PM
Re: Can’t connect a Q mini
Hi there @Tonkie I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 30 Jul 2026 08:08 PM
@Tonkie wrote:
Hi All
So any help would be appreciatedMany thanks
@Tonkie can you try swapping it with one that has been working and is nearer to the main Q box to see if it picks up the signal and updates ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 31 Jul 2026 05:52 AM
Hi
tried that, I've noticed a reset button on the back of the mini, do you think resetting it might help?
Message posted on 31 Jul 2026 04:33 PM
@Tonkie wrote:
Hi
@Tonkie you could try a reset, if you do press the reset button until the light on the front flashes red or if its already red until it flashes
