Discussion topic: Can't add Ultra HD
This message was authored by: 75JoJo
Can't add Ultra HD
Cant add Ultra HD to my package it won't add to the basket to allow me to proceed with the purchase
Re: Can't add Ultra HD
hi @75JoJo
There may be other reasons for this but I think it might not let you add UHD if your box is not UHD capable
To check which box you have, look in
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
@75JoJo also in addition to @nigea99 post do you already have the HD package ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
