Discussion topic: Can not get sky
This message was authored by: Peter6221
Message posted on 07 Dec 2025 05:33 PM
Can not get sky
Tv comes on but not with sky
my remote does nothing
Find out more
Message posted on 07 Dec 2025 07:51 PM
Re: Can not get sky
Hi @Peter6221
