Discussion topic: Cables mo longer needed
This message was authored by: scousedave
Hello
I have sky q and used to have multi room with one box , after cutting down on my bill we got rid of the multiroom but now iam left with cables I dont need fixing to the dish , can I cut these cables to remove them from my home? Is this safe to do this?
David
Re: Cables mo longer needed
@scousedave wrote:
Hello
David
Hi @scousedave
Yes, assuming the cables are not used they can be removed.
You still need the two cables from the dish to your main Q box.
Best to remove the the Screw F connectors from the dish before you cut any cables.
I'm a little confused as if you still have Q then you still need a satellite feed from the dish.
Q multiroom uses WiFi so there are no cable changes necessary if you remove a mini.
Avatar for scousedave
Hello
There was cables attached to the mini box i dont know know why when it was wifi also
  • Thanks
@scousedave wrote:
Hello
Hi @scousedave
Certainly there are no dish cable connections on Mini boxes.
Extra cables for Multiroom was a feature on Sky+HD where all extra boxes had to have their own dish connection
The cables for a mini box are a mains power lead and HDMI lead.
...you don't want to be cutting any cables feeding a satellite signal to the main Q box...
