Discussion topic: CMlni box
Message posted on 05 Feb 2026 12:50 PM
CMlni box
Please look at my last few complaints about connecting to mini box I still have a problem
why can't this problem be sorted
I did not have this problem before cable or the new router and pods
please help
Message posted on 05 Feb 2026 01:00 PM
Re: CMlni box
@Rolyhodson You're not contacting Sky Customer services by posting here, no one here can see your previous compaints, I can only find this post regarding the your mini box.
Message posted on 05 Feb 2026 01:01 PM
Re: CMlni box
Welcome to the Community. This is your first post so we certainly haven't seen any previous complaints. You haven’t actually contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Perhaps explain what connection issues you're having.
Message posted on 05 Feb 2026 01:31 PM
Re: CMlni box
please help
Hi @Rolyhodson
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
