Discussion topic: Buffering tv
Message posted on ‎20 Oct 2023 11:48 AM
Buffering tv
Can someone help to solve the problem with my tv it's buffering
Message posted on ‎20 Oct 2023 12:07 PM
Re: Buffering tv
Hi @Louieruby
Is this on live Satellite TV or Streaming from On demand?
Message posted on ‎20 Oct 2023 12:13 PM
Re: Buffering tv
Hi @Louieruby If it is just your smart TV then reboot your router by removing the power cable for 30 sec then reconnect to reboot.
If your problem is through your SKYQ main box then:-
Try rebooting your router as above, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Message posted on ‎20 Oct 2023 12:18 PM - last edited: ‎20 Oct 2023 12:19 PM
Re: Buffering tv
Live television in Sky Q (received over the satellite dish) doesn't 'buffer'.
Discontinuity in viewing is typically caused by an issue with dish alignment
