Discussion topic: Broken
This message was authored by: Suzie20
Broken
Trying to start tv up, was stuck on some random channel saying I didn't subscribe. Neither of my remotes worked. I switched everything off and now I've just got the No Signal jumping around my screen?
Re: Broken
Hi @Suzie20
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Re: Broken
@Suzie20
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
Avatar for Suzie20
Re: Broken
Hi,
I'm so technically challenged, but I know its on HDMI1.
Any idea how I rectify the problem? Thanks ☺️
Avatar for Suzie20
Re: Broken
I can't get it to green!
It's either Red or Amber?
Re: Broken
Hi @Suzie20
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
