Discussion topic: Broken picture
Message posted on 03 Jun 2025 09:32 AM
Broken picture
TV picture breaks up and sound disappears. I have to change channel and go back again for it to return. Then it repeats. This has only been an issue since we recently updated to broadband. All the Satellite and network connections are suggestion ok but it continues to distort picture and sound
Message posted on 03 Jun 2025 10:24 AM
Re: Broken picture
Hi @John1619
Message posted on 07 Jun 2025 11:53 PM
Re: Broken picture
Thank you for your guidance. I did give it a try but it didn't seem to clear the problem.
Im starting to think it's a dish issue now. The problem appears to get worse during strong winds. For the past few days it's been calm here and no tv issues. Fingers crossed 🤞
Message posted on 08 Jun 2025 08:20 AM
Re: Broken picture
@John1619 wrote:Thank you for your guidance. I did give it a try but it didn't seem to clear the problem.
I think you've just identified the problem - dish moving taking it slightly out of alignments with the satellite. Suggest you either need to book an engineer with Sky or get an independent in (at your own cost but probably quicker)
Message posted on 08 Jun 2025 08:28 AM
Re: Broken picture
As above, this sounds like a dish realignment is needed.
You can book an engineer visit online with the link at the end of this article;
