Discussion topic: Broadband
Message posted on 07 Aug 2023 03:53 PM
Broadband
While having trouble with connection between the Main Q box and my mini boxes I found out that my Main box keeps changing to an unknown internet connection
Message posted on 07 Aug 2023 08:48 PM
Re: Broadband
hi @Dicker
Who is your broadband/Home wifi supplier - if it is not SKY then the minis do not use your wifi but instead a wifi Signal that the Main box generates, so this is likely to be th enetwork you are seeing.
If you are hving problems check for anything that could be casuing interference etc. - Home DECT phones are known to be one culprit
Message posted on 07 Aug 2023 10:01 PM
Re: Broadband
Thanks for your reply
when I go to settings on my main box and check,it shows a sky internet connection,I then change it back to my BT account and my mini boxes work again
