Discussion topic: Broadband won’t connect
Message posted on 17 Feb 2024 02:30 PM
Have recently had fibre broadband put in and won't connect to my sky q box have been trying for five days keeps saying wrong password but all other items have connected ok.
Message posted on 17 Feb 2024 02:52 PM
Re: Broadband won’t connect
@Markm68 who is your broadband provider
Message posted on 17 Feb 2024 02:52 PM - last edited: 17 Feb 2024 02:53 PM
Ensure 2.4GHz is enabled and not being steered to 5Ghz.
Consider splitting SSID for both channels. Sky will only connect to 2.4GHz for non-Sky ISP.
Message posted on 17 Feb 2024 02:55 PM
Hi @Markm68
If you are on Sky Broadband then you need to use WPS.
