Discussion topic: Broadband issues
Message posted on 01 Jul 2026 10:19 PM
Broadband issues
My broadband has unconnected from my sky q tv box and will not reconnect. Broadband is very poor with speeds actually less than what your broadband checker is saying as the current speed.
Message posted on 02 Jul 2026 10:13 AM
Re: Broadband issues
@KeyC Sky's broadband checker gives the speed being delivered to your broadband Hub. If you're carrying out a speed test on a device connected by wifi the result will be lower and depending on conditons within your home, may be significantly lower.
Try restarting both your Sky Q box and your broadband Hub by switching them both off at the plug for 30 seconds or so. Let your Hub restart first, and wait until you have a connection on other devices, before turning your Sky Q box back on.
