Discussion topic: Broadband interference from neighbour
Message posted on 09 Apr 2026 05:29 PM
My SkyQ box drops connection from my Virgin router to my neighbours sky router
Message posted on 09 Apr 2026 05:36 PM
Re: Broadband interference from neighbour
Are you certain it's your neighbours network? Sky Q boxes usually show the name of their internal mesh network (something like SKY13579) and people often assume it must be their neighbours network, but it's not.
Message posted on 13 Apr 2026 12:08 PM
Thanks & yes that appears so after speaking to my neighbour yesterday !. How do I fix the issue ?
Message posted on 13 Apr 2026 12:21 PM
Can you connect via Ethernet?
As a non-Sky broadband it will only connect on 2.4GHz. Try changing the channel to avoid interferring with the neighbours. (Or they change theirs)
Message posted on 13 Apr 2026 12:26 PM
Ethernet not possible & have found out that my neighbour broadband is Virgin so no iterference from them
Message posted on 13 Apr 2026 12:42 PM
@Saffron6 wrote:...my neighbour broadband is Virgin so no iterference from them
Not sure how you conclude that. The routers are sharing the same spectrum.
Try changing the 2.4G channel.
