Discussion topic: Box won’t turn on
This message was authored by: hornet84
Box won’t turn on
Can't turn on My Sky Box!
Re: Box won’t turn on
You have posted in the wrong forum 😞
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
What have you tried? This is a Q is it?
Hi @hornet84
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
