Discussion topic: Box refuses to turn on
Message posted on 24 Jan 2024 04:38 PM
After switching off to standby at night, box refuses to respond to panel buttons and remote control. Amber light is on and internal fan is running.
Unplug, reboot and it works fine all day. Then, next morning it's the same thing. It's a new box, just 7 days old.
Any ideas?
Message posted on 24 Jan 2024 04:40 PM - last edited: 24 Jan 2024 04:41 PM
Re: Box refuses to turn on
Is this prior to 0545 (ish)? If so see this link and change the settings accordingly
https://www.sky.com/help/articles/using-the-standby-settings
Message posted on 24 Jan 2024 06:04 PM
Hi Daniel
I knew I should have added the time to eliminate the "economy setting" reason.
Nope, we turn it off around 22.00 and at anytime from 07.00 to it shuts there with it's internal fan running and Amber light on. Nothing wakes it unless you unplug it and then plug it back in again.
Thanks for your reply, I appreciate it. 👍
Message posted on 24 Jan 2024 06:43 PM - last edited: 24 Jan 2024 06:57 PM
Any ideas?
Hi @Millups
Edit
As pointed out by @Daniel0210 latest software (Q230.000)
First make sure that the Q box is on the latest Software Q230.000...........
if not update it.
https://www.sky.com/help/articles/updating-sky-box-software-sky-q.
If it already on this version
Message posted on 24 Jan 2024 06:45 PM
Latest software is Q230. Q250 is hopefully coming soon.
Message posted on 24 Jan 2024 09:56 PM
Thank you. I'll check it out.
Mildly irritating as it was only installed by sky on the 17th and it's not worked since the following morning. It's a good job I'm not a technophobic octogenarian! 🤭
Message posted on 24 Jan 2024 11:15 PM
I had a new box like this. Would do a spinning blue ring thing. Had to be replaced.
I suppose an easy answer might be a smart plug set to switch off & on every morning at 0655 😉
Message posted on 25 Jan 2024 06:47 AM
Thanks for the reply. Great idea.
I have a house full of smart lamps and smart plugs so one more on the sky box wouldn't hurt!
Anything to save a few more kWh's is always a good idea. ... An extra few pennies to spend on Amazon! 🤣
