Discussion topic: Box not working
Message posted on 13 Mar 2023 03:45 PM
Box not working
My Sky box is not working
Message posted on 13 Mar 2023 03:46 PM
Re: Box not working
It is not switching on
Message posted on 13 Mar 2023 03:57 PM
Re: Box not working
Hi @Chandigarh
What colour is the light on the Q Box?
Can you try re-pairing the remote by pointing it at the Q Box then press/hold the numbers 1 and 3 together for three seconds.
The remote should flash red a couple of times.
Afterwards try pressing the Home button to turn the Q box on.
Let me know if it works or not @Chandigarh and we'll help you further.
Tom
Message posted on 13 Mar 2023 04:14 PM - last edited: 13 Mar 2023 04:16 PM
Re: Box not working
Try pressing the power button on the front of the box. Its not obvious where the power button is but its where the light on the SKY Q box is. Not the giant blue Q light tkat lights up when something is being played. Its the one with the small led that goes amber when the box is in standby and green when the box is on. If that works your remote might need new batteries or it might need to be replaced
LG 50UQ7006
DENON X2800H 5.1.2 ATMOS
