Discussion topic: Both mini boxes not working even though they have connection to sky q box and internet connection
This message was authored by Carly30 This message was authored by: Carly30
Blank screen on mini boxes even though they are connected to main box and have a good connection to network
Re: Both mini boxes not working even though they have connection to sky q box and internet connectio
Hi @Carly30
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
