29 Nov 2023 07:22 PM
Bluetooth Voice Remote - One very useful feature on SKY Q is voice control
I find the bluetooth connection of the remote far superior & can be used over quite a distance
how do I set this up ? I have a multi room box in one room and in the next room can I watch sky on this just using the control ?
29 Nov 2023 07:25 PM
@You can only pair the Bluetooth remotes to one Q box at a time.
You cannot use it to work two boxes.
29 Nov 2023 11:56 PM - last edited: 29 Nov 2023 11:56 PM
Posted by a Superuser, not a Sky employee. Find out moreBut you can use 2 voice remotes.
30 Nov 2023 07:06 AM
Only one can be paired in bluetooth mode though.
More can be used in Infrared mode but these need line of sight & loose the voice functionality
30 Nov 2023 07:46 AM - last edited: 30 Nov 2023 07:47 AM
Posted by a Superuser, not a Sky employee. Find out more@nigea99 wrote :-
I have two voice control SKYQ remotes one connected to my main SKYQ box and one connected to my Mini box upstairs.
So would have to agree with @Chodley suggestion above.
30 Nov 2023 07:56 AM - last edited: 30 Nov 2023 07:58 AM
@Quoman7 wrote:
@nigea99 wrote :-
Maybe I needed to be clearer I was referring to paring with a single box.
As @oldfella says you can't pair/use a remote in bluetooth mode with more than one box & you can only pair one remote to any given box in bluetoorth mode
Thus in bluetooth/voice mode it is a 1-1 pairing
You can use more remotes with any box in Infrared mode
30 Nov 2023 08:01 AM
Posted by a Superuser, not a Sky employee. Find out more@nigea99 makes more sense now 👍 I should have read the op initial post better.
30 Nov 2023 08:32 AM - last edited: 30 Nov 2023 08:35 AM
Some answers have been given here but I am not fully convinced I fully understand what you are asking (I note you have quoted something from my notes on SKY HD to SKY Q)
Do you currently have SKY Q or just multiroom on SKY HD ?
BTW if you are asking about whether you can control a box from a nother room using bluetooth then usually the answer is yes - I did a test with my main box by front window in an alcove & I have controlled it from my back garden (so through 2 wqall & 2 rooms) and also from my upstairs room.
But you should note that SKY Q is not designed for watching in any other room than it is positioned - it does not have RF outputs. That said I think some people have managed with HDMI splitters but it needs good research
If you can give us any more info on what you wish to do or have any other questions please do not hesitate to ask& we will endevour to answer
30 Nov 2023 08:37 AM
Posted by a Superuser, not a Sky employee. Find out moreI re-read the OP this morning and have the same question. How is the picture going to get from one room to another? HDMI through the wall perhaps?
30 Nov 2023 09:45 AM - last edited: 30 Nov 2023 10:09 AM
Hi @Chodley
He says he has Multiroom and so so has more than one TV.
Edit
I assume that he thought only the main Q box came with a voice remote and was asking if he could control both TV's with one Bluetooth remote.
Infrared use is of no use to him if he wants Voice control.
Just to clarify @Scottietohottie all Q boxes including minis come with a Bluetooth Voice remote.
@nigea99 has raised the point that you may have Sky+ Multiroom.
If this is the case and you are thinking of changing to Q. Are you asking if the Q remote will work your existing Multiroom Sky+box.? If so it will not and if you do change to Q your existing Sky+ subscription will cease anyway and your existing boxes will no longer function with Sky TV.
30 Nov 2023 10:18 AM - last edited: 30 Nov 2023 10:18 AM
@oldfella wrote:
@Chodley wrote:I re-read the OP this morning and have the same question. How is the picture going to get from one room to another? HDMI through the wall perhaps?
Hi @Chodley
Edit
That was my first take on it but the OP says "I have a multi room box in one room and in the next room can I watch..."
30 Nov 2023 10:53 AM
Posted by a Superuser, not a Sky employee. Find out moreNo problem. Browse or search to find help, or start a new discussion on Community.
