Discussion topic: Blue screen
Message posted on 12 Mar 2026 06:47 AM
Blue screen
My television keeps popping up with a blue screen with loading written on it.
I have switched everything off unplugged the Q box anc television left for 5 minutes then switched back on. I have done ghis twice, but it still keeps happening
Message posted on 12 Mar 2026 08:02 AM
Re: Blue screen
Loading? Just that? Don't think that seems like a sky box message...
Message posted on 12 Mar 2026 09:20 AM
Re: Blue screen
I've got the exact same problem. Since yesterday morning when watching recorded programmes the screen goes black then blue with loading and a spinning circle in the centre and the q light on the box also goes off. Pressing the SKY button on the remote gets rid of it and the programme continues playing but it's very annoying. Apps and live tv are fine, and can still download on demand content so I haven't reset the box. Anyone know if there's been another glitchy update pushed out?
Message posted on 12 Mar 2026 09:48 AM
Re: Blue screen
@Monstera wrote:I've got the exact same problem. Since yesterday morning when watching recorded programmes the screen goes black then blue with loading and a spinning circle in the centre and the q light on the box also goes off. Pressing the SKY button on the remote gets rid of it and the programme continues playing but it's very annoying. Apps and live tv are fine, and can still download on demand content so I haven't reset the box. Anyone know if there's been another glitchy update pushed out?
That sounds like a knackered hard drive
Message posted on 12 Mar 2026 04:42 PM
Re: Blue screen
That's what I was hoping it wasn't. Only had the box for 3 years as well. thanks anyway 👍
Message posted on 14 Mar 2026 09:05 AM
Re: Blue screen
Mine keeps doing the same. Blue screen. Loading. Press a button and it goes. Sky Q.
Message posted on 15 Mar 2026 08:48 AM
Re: Blue screen
Exactly the same issue here.
Watching live TV and suddenly a blue screen with loading pops up.
You can exit out of it, or it will do it itself in about 20 seconds.
Doesn't do it any other time, only when watching live TV
Message posted on 17 Mar 2026 11:20 AM
Re: Blue screen
This has happened to me as well. It can't be a coincidence?
