3
This discussion topic has been answered Discussion topic: Blue screen on all channels
This message was authored by: Liz2026
I cannot watch tv on my mini box - I get a blue screen on all channels and my recordings are unavailable. I have tried re booting and it's connected to the broadband etc but still not working. My main box is fine - it's just the mini box that's the problem. Pretty sure it's broken but can't get a number to ring anyone 🤦‍♀️
This message was authored by: Laing1 Answer
Re: Blue screen on all channels
@Liz2026 Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
then
Avatar for Liz2026
Thanks- I did try that and it's worked 😊👍
This message was authored by: shannonk96
I'm having the same issue but on my sky q box. I resetted it and it was fine for about ten minutes and now it's gone back to a blue screen with apps not working and recordings not working either.
