Discussion topic: Blown Sky Box
This message was authored by: BB2025
Blown Sky Box
One Sky boxes was blown with lightening and Sky had just told us there are no boxes any more and left it at that. We have a subscription so how do we use it. Sky support was zero help
Re: Blown Sky Box
Re: Blown Sky Box
Hi @BB2025
Is this Sky Q boxes or Sky+HD.
If Sky Q replacement boxes should be available from Sky although they are likely to be refurbished ones.
If you have Sky Q you need to persevere with Sky contact.
Re: Blown Sky Box
Simply not true: Q is still a live product and Sky has literally millions of Q boxes
They won't, however, supply a Sky+ HD box, and Viewing Cards can no longer be transferred to second-hand hardware.
Avatar for BB2025
Level 0 icon
Re: Blown Sky Box
It is not a Sky Q box so I know the old ones are not available but why didn't they give me the steps to replace ??
Re: Blown Sky Box
Hi @BB2025   I would try again, but this time ask to be changed to Sky Q.
Re: Blown Sky Box
Note that it will require an engineer visit to change the LNB on your dish (assuming you have your own dish)
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
This message was authored by: Marlu-Nyu
Re: Blown Sky Box
If it's an old Sky Digibox, or a Sky+ (SD) or a Sky+HD box*, they don't make them anymore.
However, if it's a Sky Q, Sky Glass or Sky Stream, these are all still being make.
Long story short, to officially get your Sky back, you'll need to upgrade to Sky Q, Sky Glass or Sky Stream. You may be able to buy a used Sky+HD box online, and get Sky to connect it, but I don't know if they will, or if it will work.
* Reference: https://helpforum.sky.com/t5/Sky/Replacement-Sky-HD-Box-needed/td-p/4861640
Sky Q (with Sky Cinema & Sky HD) • Sky Broadband (Fibre) • Sky Talk (VoIP)
Disney+ • Paramount+ • HBO Max • Discovery+
Re: Blown Sky Box
@Marlu-Nyu OP has already confirmed they don't have a Sky Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Blown Sky Box
I know, I read it, I'm writing it for other users who may come across this and have a similar issue. They may benefit from my comment.
