Discussion topic: Blank screen
This message was authored by: driver35
Blank screen
Screen keeps going blank, Q box making noise Luke over heating and Q sign is pulsing blue. Have reset box numerous times.
Coincidence that this happens after I give notice to cancel
Re: Blank screen
Hi @driver35
Avatar for driver35
Re: Blank screen
Only staying on for about 20 seconds at a time so not able to get to that
Re: Blank screen
Hi @driver35
Try the Following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
