Discussion topic: Blank screen after power on
This message was authored by: Lee+Rowley
I have powered the Q box, sound bar and TV on using the Home button for as long as can remember. Now though everything powers on, but the screen stays blank. Numerous power cycles, it usually comes on. More recently though, it is becoming frequent. I am needing to unplug the Q box before it will go to the Homescreen.
I've seen others with this issue, but not found a solution.
Has anyone got any pointers?
This message was authored by: Addie15
Re: Blank screen after power on
Avatar for Lee+Rowley
Level 3 icon
Went through a few thing with a SKy advisor, most of which I had treid anyway, and I suggested that we turn off HDMI control. It looks like this is the main cause; some timing error, software bug in the HMDI control. I have to turn my TV on manually, but so far, touch wood, Sky Q displying the home screen every time since turning the HDMI control off.
Update-We are closing this session now but if there is anything else we can help you with in the future, please do not hesitate to reach out. Thanks.
Level 3 icon
Just a quick update, since turning off HDMI control on the SkyQ it has powered properly everytime.
(It is still enabled on the TV (LG OLED, SIMPLINK) as this outputs sound to the soundbar)
So if anyone else has similar issues try turning off HDMI Contol.
