Discussion topic: Black Screen,with sound, remote doesn't work
This message was authored by: PhilW_
Hi all, hoping for some help as can't figure out. Tv is black screen, sound plays through TV. Remote on Sky Go works OK to change channels however physical Sky remote is not working. Anyone any ideas please? I would just blame the TV however seems strange that physical Sky remote is not working either.
Re: Black Screen,with sound, remote doesn't work
Hi @PhilW_
First try rebooting your Television set by disconnecting the power lead for 30 seconds and then reconnecting.
When this is back up and running rebootyour Q box?
If the remote is still not working , with the Q box on with green led try completly resetting your Bluetooth remote.
Avatar for PhilW_
Thank you for the help. Unfortunately that hasn't corrected the issue. Screen is still black. However the remote does seem to be working now. I think potentially issue with the TV. I appreciate the advice though! Will update this thread when checked the tv
